In line switch
Kcarlin
In line switch
by Kcarlin » Mon Mar 17, 2008 7:05 pm
How do I wire an in line switch for my 2 core bedside lamp
by ericmark » Wed Mar 19, 2008 1:53 am
This can vary according to the switch but but normally you need to very carefully remove a section of outer flex then cut only the brown wire and put this across the switch leaving blue and if exists yellow/green untouched. Some switches are double pole and then you need to cut blue as well but that is unusual.
It is currently Thu Jan 16, 2025 5:45 pm
