Direct Unvented Water - SCx 130d OR Megaflo DD125HE125
10 posts   •   Page 1 of 1
Kalel
by Kalel » Tue Mar 18, 2008 2:42 pm
Hi, I have decided I need Direct Unvented Water for my 2 bed flat and can't decide between the 2 options.
Dimplex - SCx 130d
OR
Megaflo - DD125HE
Any advice or opinons most welcome
Thank you
MB
by MB » Thu Mar 20, 2008 5:39 pm
Do have good water pressure to your flat? If you don't then unvented could be a costly purchase and may not give you the performance you are hoping for.
Kalel
by Kalel » Thu Mar 20, 2008 9:15 pm
I tested it the other day using a pressure tester at the washing machine pipe and it was 3 bar.
MB
by MB » Tue Mar 25, 2008 4:15 pm
3 bar would be fine for an unvented system. You can't go far wrong with a megaflo. When purchasing the cylinder don't be duped into buying a bigger one than you need. I am presuming that in your flat you only have one bathroom and possibly an ensuite? If you are only intending to have two showers or baths on the go at any one time you won't be needing a massive cylinder. MB
MB
by MB » Tue Mar 25, 2008 4:22 pm
Its also worth adding that when you are doing your pressure test at the washing machine tap get someone to flush your toilet at the same time so you can get a true reading when the system is being used ie theres water being drawn off somewhere ie the toilet.
Kalel
by Kalel » Wed Mar 26, 2008 8:29 am
Thank you for your help and assistance. I'm now trying to convince the block manager that I need to have a pipe running down the outside of the block...God give me strength :(
Kalel
by Kalel » Tue Apr 01, 2008 6:59 pm
Ok, so they said no I can't have the external waste pipe running outisde the flat. Can they stop me from doing this? is there any way to make an internal adjustment so the overflow pipe can use the internal drainage system?
MB
by MB » Sun Apr 06, 2008 11:05 am
You can vent the pipe out through the wall then bend it back so it vents down the wall. You should contact your local building control officer and ask if thats a viable option. As far as connecting into existing waste pipes -you shouldnt do it because if the unvented cylinder starts discharging water it will be in the high 90 degree mark and will deform your plastic waste pipes.
Kalel
by Kalel » Mon Apr 07, 2008 9:49 am
Thanks for the feedback, Will call the Council today. What a mission!
Kalel
by Kalel » Tue Apr 08, 2008 11:09 am
Spoke to the regs dept who said whatever your plumber is happy to do we are happy with. They wanted to know that I would use a corgi registered plumber and thats it. So not much help there.
Can any corgi guys on this site offer some help please?
It is currently Sat Nov 23, 2024 3:37 am
