Leaky wet pipe
cuteboxerdog
Leaky wet pipe
by cuteboxerdog » Sat Apr 21, 2007 6:22 pm
Hi - Please can you give me any advice. There is a drippy leak in my outside toilet - clean water. I can't turn the water off as it is in the road and I want to see if I can cure it first.
Is there anything on the market that I can buy to cure the leak? of course the pipe is wet with the drip so it would need to be a strong sealant. Thanks
thedoctor
by thedoctor » Sat Apr 21, 2007 9:10 pm
Need to know where the leak is coming from. Pipe going in or pipes coming out ?
cuteboxerdog
Leaky wet pipe
by cuteboxerdog » Sat Apr 21, 2007 10:04 pm
The pipe carries clean water from outside going into the sistern Thanks
thedoctor
by thedoctor » Mon Apr 23, 2007 8:58 am
This should ne a nut on the end of the copper pipe which turns onto a metal or plastic thread to connect to the cistern. Turn the water off, undo the nut, if there is a washer in there, replace it and wrap some PTFE tape around the thread. See the project on copper compression joints to find out about PTFE tape.
It is currently Sun Dec 22, 2024 10:12 am
