Moving UPVC windows
paddyarm2k@yahoo.co.uk
Moving UPVC windows
by paddyarm2k@yahoo.co.uk » Thu Mar 20, 2008 6:17 pm
I have an extension project which involves moving a number of UPVC windows. It is essential that the windows are removed without damage as they are getting re-used. I would also like to minimise the damage to the brickwork if possible.
What would be the best method of doing this?
doodle bug
by doodle bug » Wed Apr 02, 2008 7:56 pm
the easy way to move your units is,first remove all glazing bars.then take out the double glazed unit,then run a stanley knife round the edge of the frame to get the sealant mastic of,locate all screws and remove.finally remove the frame,you should'nt get any damage.
Gary B
by Gary B » Tue May 13, 2008 1:14 pm
Hi doodle bug.
What are "Galzing bars", and how do you remove them? And of coarse, how do you replace them once glazed unit is replaced?
Gary.
stevenc1603
by stevenc1603 » Thu May 15, 2008 11:30 am
Gazing bars are the beads that hold the glass units in place.
See you're other post for how to remove and replace them.
It is currently Fri Nov 22, 2024 6:31 pm
