Integrated Washing Machine
6 posts   •   Page 1 of 1
Spanner
by Spanner » Thu Mar 20, 2008 8:06 pm
Hi, I have an integrated washing machine which keeps filling up with water even when it is not on(usually happens over a period of 36 hrs before it needs emptying). Any ideas what the problem could be, does it sound like machine fault or something else?
stevenc1603
by stevenc1603 » Fri Mar 21, 2008 12:25 pm
If its continually filling with water I'd say the inlet valve is either broken or blocked and not closing fully.
Would need cleaning or replacement to cure it.
This is of course assuming its fresh water that's filling it, not waste water.
Spanner
by Spanner » Fri Mar 21, 2008 4:43 pm
Hi, thanks. Where would I find the inlet valve? Would this be at the washing machine end or where the hose connects to the water?
by ericmark » Mon Mar 24, 2008 10:48 pm
washing machine end normally just inside the machine.
stevenc1603
by stevenc1603 » Tue Mar 25, 2008 10:19 am
It will be inside the machine. If your looking yourself remember to unplug first.
Take the top off and have a look on the inside where the water hose is attached. The valve will either be there or it will be built into the drawer assembly where the water fills the machine from.
I don't know how easy it will be to remove the valve and see what's wrong.
Another thought I just had. It could be that the water pressure is too high for the valve to hold back. Try closing the valve that the hose connects to on your plumbing a little and see if that helps.
TheDoctor5
by TheDoctor5 » Tue Jan 20, 2009 10:26 am
It is currently Fri Nov 22, 2024 5:35 am
