LACK OF HOT WATER IN SHOWER
MYGAYCAT
by MYGAYCAT » Fri Mar 21, 2008 11:46 am
While the rest of my central heating is working fine my gravity fed shower will only run turbo hot for about 30 seconds and then run luke warm no matter what settings i have my central heating on. Has anyone got any ideas????
Skids
by Skids » Fri Mar 21, 2008 8:27 pm
Hi MYGAYCAT,
The CH should not be on the same circuit as the hot water!!
How is the hot water from the rest of the hot taps ?
Check the HWC temperature setting, the thermostat?
What size is the HWC?
If the water is lukewarm in the Hot Water Cylinder, you maybe emptying it so quick with the ‘turbo shower’ that it cannot heat up in time?
add some more info ?
Regards
Skids
It is currently Tue Jan 07, 2025 9:30 pm
