Clearing out a bridged cavity
Jim A
by Jim A » Sat Mar 22, 2008 9:27 am
Can anyone advise on the best way to clear out a bridged cavity?. Should you remove just one brick from the external wall at a time, or is it ok to remove several, to give better access?.
tucny
by tucny » Sat Mar 22, 2008 11:03 pm
remove one miss say two then remove another. do this to say a two meter section at a time and replace bricks before moving on.
Jim A
by Jim A » Sun Mar 23, 2008 9:51 am
Thanks tucny!. When you say about 2 metres, do you mean 2 square metres ie. remove the bricks bith horizontally and vertically?
tucny
by tucny » Mon Mar 24, 2008 6:36 pm
horizontally, say the second course above the dpc. Im assuming that you want to make sure there isnt any debris in the cavity that could bridge the dpc?
Jim A
by Jim A » Tue Mar 25, 2008 8:08 am
That's correct -thanks again tucny!
It is currently Sat Nov 23, 2024 12:17 am
