Bathroom shaverpoint.
Dusty Bin
by Dusty Bin » Sat Mar 22, 2008 12:15 pm
I want to fit a shaver point in my bathroom. Is it O.K. to use the cable supplying power to the bathroom light -which would be very easy- or will I have to run a cable from the mains -which is more difficult.
Would appreciate advise.
Many Thanks.
by sparx » Sat Mar 22, 2008 3:21 pm
Hi assuming you are prepared to take a chance on doing reportable works yourself [see 'projects' Part-P building regs] then most likely you can take from light fitting, if more than one cable @ fitting then is possible.
Dusty Bin
Bathroom Shaverpoint
by Dusty Bin » Sat Mar 22, 2008 4:55 pm
Thanks for your comments, and your swift response.
It is currently Thu Jan 16, 2025 7:35 pm
