decorators caulk edging wallpaper
Arbies
by Arbies » Mon Mar 24, 2008 10:02 am
hi, we had someone in to wallpaper a wall and he used decorators caulk (looks like sealant) to neaten the edges. (doesn't look v. professional but it's done now!)
I have to remove and refit the mantelpiece which has been outlined with the decorators caulk. How do I remove the caulk without damaging the paper because I am not ready to re-paper the wall!
Thanks for reading!
rosebery
by rosebery » Mon Mar 24, 2008 2:46 pm
Very carefully and with a very sharp blade.
Arbies
by Arbies » Tue Mar 25, 2008 12:19 pm
Thank you v much. Not really steady but will give it a go!
the paint pot
Re: decorators caulk edging wallpaper
by the paint pot » Sat Mar 29, 2008 1:44 am
[quote="Arbies"]hi, we had someone in to wallpaper a wall and he used decorators caulk (looks like sealant) to neaten the edges. (doesn't look v. professional but it's done now!)
Thanks for reading![/quote]
hi if you use a hair dryer to heat up the chulk it will come of easy
i use this all the time
hope this helps
It is currently Tue Nov 26, 2024 6:59 pm
