plastic caps of radiator valves
6 posts   •   Page 1 of 1
sallyh
by sallyh » Tue Mar 25, 2008 1:25 pm
the plastic tops of my radiator valves need replacing as they are filthy and i cant get them clean. I can only seem to find the whole valve which is £££. Does anyone know if I can buy the plastic parts anywhere?
thanks
Sally
ALDA
by ALDA » Tue Mar 25, 2008 6:58 pm
REMOVE, PAINT AND REPLACE.
USE PLASTICOAT SPRAY PAINT.
by htg engineer » Tue Mar 25, 2008 8:31 pm
A clue as to the make and model may help answer this post.
sallyh
by sallyh » Fri Mar 28, 2008 1:39 pm
its honeywell and i think it must be the VT117E model. dificult to see for the old plaster all over them
thanks
by htg engineer » Fri Mar 28, 2008 10:05 pm
Had a look and the replacemant caps are the same price as the whole valve - is ALDA's suggestiong a possiblity or are they too far gone ?
ALDA
by ALDA » Fri Mar 28, 2008 10:59 pm
SALLY,
REMOVE CAPS.
PLACE IN PAN AND COVER WITH STRONG VINIGER/WATER SOLUTION.
BRING TO THE BOIL AND THEN REDUCE TO A SIMMER UNTIL DEPOSITS LOOSEN.
CAPS MAY THEN BE REUSEABLE AS IS,
OR
SPRAY AS PREVIOUSLY SUGGESTED TO IMPROVE.
I SHOULD HAVE BEEN A COOK!!!
ALDA
It is currently Tue Nov 26, 2024 7:12 pm
