adhesive for fire bricks
by welsh brickie » Tue Jan 19, 2010 8:38 pm
whats the best adhesive for fixing fire bricks, the bricks are 20mm thick and I am building fireplace so I want to line the inside with a herringbone
design.
thanks
chris_on_tour2002
by chris_on_tour2002 » Thu Jan 21, 2010 2:55 pm
hi mate,
is there any reason why you can't just use a fireproof cement mortar?
by welsh brickie » Thu Jan 21, 2010 6:22 pm
[quote="chris_on_tour2002"]hi mate,
is there any reason why you can't just use a fireproof cement mortar?[/quote]
I would do but tried everywhere to get it,the only thing they seem to have is either tile adhesive,or heat resistant plaster (siva Alci)
chris_on_tour2002
by chris_on_tour2002 » Tue Jan 26, 2010 1:48 am
a bit confused for a moment as fireproof cement is available at any decent builders merchant. then i noticed from another post you mention that you are in turkey? is that where the property is?
my brother in law is a stone mason and has been making and fitting granite fireplaces for years in jersey.
he tells me that he never uses fireproof cement and never has. just ordinary cement mortar and never had one fail. and in a tiny place like jersey he'd know about it if one were to fail so you might want to consider just normal mortar.
by welsh brickie » Wed Jan 27, 2010 5:24 pm
[quote="chris_on_tour2002"]a bit confused for a moment as fireproof cement is available at any decent builders merchant. then i noticed from another post you mention that you are in turkey? is that where the property is?
he tells me that he never uses fireproof cement and never has. just ordinary cement mortar and never had one fail. and in a tiny place like jersey he'd know about it if one were to fail so you might want to consider just normal mortar.[/quote]
thanks mate i wil try that
It is currently Sun Dec 22, 2024 9:33 pm
