URGENT-Help needed with central heating problem
shoaghal
by shoaghal » Fri Jun 08, 2007 11:49 pm
I turned off gas supply before leaving on vacation. Now the central heating is not working. Gas supply is OK. How do I know what type of heating system I have? There's a big sealed cylinder with a dozen pipes running to it.I used to only turn on a switch to have hot water.
Would appreciate any help, I should be missing something very small.
by htg engineer » Sat Jun 09, 2007 7:52 pm
Is there a pilot light on the boiler ? that would of gone out if you turned off gas supply, it may take a while for the pilot to light as the gas pipes will be full of air, so its best to light the gas fire and any other gas appliances first.
It is currently Mon Jan 20, 2025 9:10 am
