Preparing to fill wall void to prevent damp
Housediy
by Housediy » Sun Oct 18, 2020 2:46 pm
I have removed the window trim on the inside because of a damp patch under the window sill. It has revealed what appears to be blocks of wobbly mortar or plaster on the inside with space around it. How can I seal it to prevent the damp? Do I need to remove the wobbly plater/Mortor or whatever it is first? If I do the hole will be bigger.
Thanks guys
Housediy
Re: Preparing to fill wall void to prevent damp
by Housediy » Mon Oct 19, 2020 5:37 pm
the large exposed bit at the bottom is wobbling. Is it plaster or mortar
Please see pictures
Please see pictures
It is currently Sun Dec 22, 2024 6:45 am
