Removing a wall
Createv
Removing a wall
by Createv » Thu Mar 12, 2009 10:33 am
Hello
I am looking to remove a wall that is constructed using a wood frame then covered with plasterboard both sides.
The wall splits the downstairs kitchen and dining room, I have lifted the floorboard's in the bedroom above and the joists are running parallel with the wall below.
Is it ok to remove I don't think it's a load bearing wall
Any thoughts on this
Thanks/
rosebery
by rosebery » Thu Mar 12, 2009 6:40 pm
If its a stud wall as you suggest then its almost certainly not load bearing.
Its Ok to remove a non loadbearing wall.
Createv
by Createv » Thu Mar 12, 2009 10:18 pm
THANKS
It is currently Sun Dec 22, 2024 12:30 pm
