Load Bearing Wall
Posted: Mon Nov 23, 2009 8:16 am
by jez937
Hi All, I hope someone can help. We are hoping to make some adjustments to our loft to increase the living space in our bungalow. We have removed a window from what was an external wall and above this is a 7" x4" length of wood which sits on the brick. Will this suffice as a lintel or do I need to reinforce this with a catnic lintel?
Many thanks.
Posted: Tue Dec 08, 2009 6:04 pm
by Perry525
I am not sure I understand the question. But here goes.......
First of all is the wall load bearing - if it is take extra care.
If it is not load bearing then all a lintel does is support the weight of the wall inside a triangle of 45 degrees from the edges of the opening.
Brick comes in around 45 kilos/one hundred weight a cubic foot.
For an opening the size of a typical door, no problem.
As an opening gets wider you need to take into acount the damage the masonary will do if it falls and provide support while working. You will also need a suitable steel lintel - keep in mind you will have to lift the lintel into place and these things can be heavy.
Re: Load Bearing Wall
Posted: Thu Jan 28, 2010 8:54 am
by benyboy
[quote="jez937"]Hi All, I hope someone can help. We are hoping to make some adjustments to our loft to increase the living space in our bungalow. We have removed a window from what was an external wall and above this is a 7" x4" length of wood which sits on the brick. Will this suffice as a lintel or do I need to reinforce this with a catnic lintel?
Many thanks.[/quote]
I would always get an engineer in to confirm any structural calculations - especially if you have a loft conversion above any structures that you are altering
Local help at hand!
Posted: Thu Jun 24, 2010 10:14 pm
by TheDoctor4
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
Posted: Mon Jul 12, 2010 7:41 pm
by DevilDamo
Why do you need to do anything with the existing lintel/support?
reply
Posted: Wed Aug 04, 2010 7:21 am
by Eva2100
wish you have solved your prolem..
