window replacement--lintels?
Posted: Sun Jan 31, 2010 11:29 am
Hi All--"new poster" Alert.
My house is fitted with slightly worn hardwood windows which only have a 12mm d/g gap, and I'm looking to replace them with the better sound and heat insulation of (relatively) maintenance free UPVC. The windows will be going into the original Victorian brick-arched openings; when the existing hardwood windows were put in by the previous occupier, some work was done on the inside to tidy up the plasterwork, and the top and sides of the internal window reveal have been reconstructed.
My question is this: given that theres been no apparent movement of the brickwork in the 20 or so years that the existing windows have been in, can I assume that theres sufficient structural strength at the head of the openings and do a straightforward replacement without exposing the internal brickwork and checking the condition of the lintel? The openings in which I'm looking to fit replacements are on average just under a metre wide and around 1700mm high: had there been a problem with the window structure, would the existing hardwood windows have been of sufficient strength to take the weight of the brickwork above, and might the installation of UPVC expose any weaknesses? Lastly (long shot, this) is there any way of checking the adequacy of the window support without exposing the internal brickwork?
Sorry its a bit long, but any advice would be appreciated. Ta.
