Need to extend a porch
Posted: Tue Sep 07, 2010 9:25 am
by happyhacker
I have a porch off the kitchen which is only wide enough to walk through. I would like to extend it widthways to take white goods (w/machine, freezer). It is about 8' x 4'wide and I want to add say 2'6". It has a pitched roof which would need altering to take the extra width (don't want a flat roof. As fas as I know the entrance is not "living space" and is not heated.
Would I need Planning and building permissions? The proch is on the back of the house and not really visible from the street. The property has not been extended and is about 1970's.
Many thanks.
Posted: Fri Sep 10, 2010 5:34 pm
happyhacker,
Do a sketch, put dimensions on it - especially boundaries and go and talk to your local planning department.
You will not need building regs because it is not a habitable room.
Posted: Wed Oct 20, 2010 4:26 pm
by DevilDamo
If the proposed works are structural, then you may require Building Regulation approval. Check with them first who should be able to give you a simple yes/no.
Posted: Wed Oct 20, 2010 7:21 pm
by happyhacker
Many thanks for your input. I will check with BR dept.
