plastic windows cill drainage
Posted: Fri Apr 08, 2011 4:24 pm
by bobble
I have specified plastic windows directly onto a concrete cill without a plastic cill. The contractor has installed windows with bottom drainage instead of face drainage. The contractor has ceased trading. I am arguing with the manufacturer that they should have provided face drainage in windows supplied without a cill. Am I right?
face drain cills
Posted: Tue Apr 12, 2011 7:03 pm
by welsh brickie
the contract was between the supplier and the contractor sounds like the contractor was at fault,unless you can find a specific paper stating said cills,unfortunatly there is not a lot you can do.
Posted: Tue Apr 12, 2011 8:46 pm
by Perry525
Window cills are designed and fitted with good reason.
Without the offset and drip of a window cill, the vast quantities of rain will run into the wall making it damp.
Most builders yards, and Wicks have window cills.
