Concrete Guttering
Posted: Thu Jan 17, 2013 5:17 pm
by aidmerrick
Hello,
I have issues with my concrete guttering causing damp in the upstairs bedroom.
Does anyone know of any specialists in concrete guttering?
Aid
Re: Concrete Guttering
Posted: Thu Jan 17, 2013 6:22 pm
by jamesdavid23
My house had finlock guttering, I had a similar problem but to the back of my house. I rang several companies who gave me contrasting prices for the work but I found the best quotes for front and back were from a company called finlock solutions. I paid 2900.
www.finlocksolutions.com
Hope this helps
Posted: Thu Feb 19, 2015 11:49 am
by puaa001
The flashing sealing the joint between your chimney stack and roof may have cracked or become dislodged, allowing water through the joint. You'll need to refit the loose flashing, or if it's damaged, replace it with the same type of flashing or a self-adhesive flashing strip.
A damp patch or mould has formed at the top of an upstairs wall
Blocked or broken gutters will send water gushing down your wall, and possibly saturate it. You'll need to clear your gutters or repair the damaged ones.
