Advice on Brick Arch Damage After Removing Render
AlanWick
by AlanWick » Fri Aug 23, 2019 9:20 pm
Hi all,
I’ve recently been removing render from an alleyway that lead to my property as most of it was cracked and hanging off the walls. In doing so I’ve exposed a number of areas of dodgy brickwork that will require repointing. The bit that concerns me most however is the archway lintel as it looks a bit rough. Can anyone provide any advice / guidance / reassurance based on the photo I’ve provided below as to whether I should be concerned and what I should do to ensure this is safe??
https://www.instagram.com/p/B1hMPHcAt8d ... ohzm4v5msn
It is currently Thu Jan 02, 2025 11:02 pm
