Regulations for rebuilding demolished building
Posted: Wed Aug 03, 2022 2:29 am
by Nav786
Need advice please.
I bought a derelict building 12 years ago. Building had roof totally collapsed in, external walls were still intact for few years before they also started to lean over. So i finally decided to demolish the whole building & get rid off all materials.
My question is can i build the same building again as it was 20 years ago? Or will i need planning permission? My concern is if I submit a new application then most likely planning department will refuse my idea. So i thought they might not refuse if i rebuild what was already there.
Re: Regulations for rebuilding demolished building
Posted: Sat Aug 06, 2022 9:45 pm
Hi nav786,
You may have shot yourself in the foot, your local planning department may well refuse an application and also take action against you if you rebuild without permission.
Posted: Sun Aug 07, 2022 12:07 am
by Nav786
I thought that might be the case. I just wanted someone with knowledge give me advice.
Thank you
