Internal insulation on barn conversion
Posted: Thu May 28, 2009 1:07 pm
by Llanfab
We are about to commence a barn conversion. We very much like the look of bare stone walls and would like to retain this internally if possible. We are not sure where we stand with building regs and U values. We understand that not insulating the walls internally will be frowned upon, but feel that insulating and drylining them will detract from the character of the building.
The walls that we would like to leave bare only cover a small area, about 15% of the building perimeter.
The walls are two foot thick and of a random stone construction.
We are unclear if the SAPs calcs will allow us to do this as the rest of the building will be fairly well insulated.
Any thoughts would be appreciated.
Posted: Fri May 29, 2009 9:08 pm
by bd3cc
What does it say on the plans? If it shows stone then you can use stone, otherwise you might need to negociate this with BC. They are generally helpful.
Posted: Tue Jun 02, 2009 11:05 am
by Llanfab
We are in the process of drawing up the plans.
Our Architect thinks we will have to have internal insulation.
They are pretty thick walls, so we were wondering if there are any exceptions to the rule. I appreciate it's probably different for each county.
We wondered if we were to super-insulate the rest of the building, if it would make up for any heat loss on this wall (do they work out the SAPs calcs per room, wall, or floor space etc?)
We will certainly have a chat to BC and see if there is any way it is possible.
Cheers.
Posted: Tue Jun 02, 2009 6:31 pm
by Perry525
Modern 28mm double glazing is good but, treble glazing is better.
Have you considered external insulation?
You should be able to cover this to suit.
Posted: Tue Jun 02, 2009 9:51 pm
by bd3cc
I am sure their is a way round it, even if you have to build a false, stone wall with insulation behind it.
Not sure of the exact calculations, but it will not vary by county.
Tell your architect what you want, and ask him how to achieve it, as you are paying him to achieve what you want.
Posted: Fri Jun 05, 2009 11:03 am
by Llanfab
Many thanks for your input.
The walls and pillars are of local stone and rubble construction edged in bull-nosed bricks. The particular wall that we have in mind has a beautiful, full height arch on the gable end, also edged in brick. We feel this would make a fantastic feature - hence why we are reluctant to have to cover it up!
We have arranged to see someone who specialises in SAPs calcs and also have a contact of a conservation officer locally.
Good point about the architect - we will see what he can come up with.
Seems a shame to have bought the barn partly because of it's character and internal features, only to be told you have to cover them all up!
Not giving up just yet though - as you say, I'm sure there is a way round.
Thanks again. will let you know how we get on!
Posted: Wed Jun 24, 2009 12:27 am
by geordiesworld
yes we had the same thoughts about the barn on our farm which we are now converting. We were forced to go down the route of installing a kit frame incorporating insulation, finished surface being plasterboard. Our walls are 540 mm or about 20 inches very rough rubble and block soft sandstone covered with layers of whitewashs over the years as it has been a working building for a long time. We have settled with the idea, as there seems little other option unfortunately.
Would be interesting to see what your outcome is ..
George
Posted: Wed Jun 24, 2009 11:46 am
by Perry525
You could build a wood based structure inside the room (taking care to avoid damage to the arch) then carefully remove it after all is done and dusted!
Help from DIY Doctor!
Posted: Thu Jul 22, 2010 9:08 pm
by TheDoctor4
If you would like to find a reliable, insured and vetted tradesman in your area why not click through to the Find a Tradesman area of DIY Doctor: https://www.diydoctor.org.uk/find_tradesmen/ , complete the form and receive up to 5 FREE quotes
