How to find the thickness of flooring boards
stronach
by stronach » Tue Mar 12, 2013 4:13 pm
I live in a 17 yr. old property where the upper flooring was laid using 8 by 4 sheets of what I call blockboard, probably not its proper name. The upper walls were then fitted on top. What would have been the thickness of this boarding as I need to screw it down in alot of places as it creaks badly when walked on. If I know its thickness I can then get the right length screws. I did contact the builders of the property (Bloors) but they couldn't be bothered to reply.
Re: floor thickness
by welsh brickie » Tue Mar 12, 2013 7:17 pm
usual thickness is 18mm
stronach
Re: floor thickness
by stronach » Fri Mar 15, 2013 6:35 pm
Have only just seen your reply welsh brickie, many thanks for that.
It is currently Fri Oct 18, 2024 11:21 am
