Drilling into Breeze Block to put up a shelf
Posted: Thu Dec 06, 2007 8:28 am
by shoesmc
Hi, Whats the easiest way of drilling directly into breeze block, as you know this can start to crumble and the bit can move around.
Posted: Sat Dec 08, 2007 7:19 pm
by marrtin
Nice sharp drill bit and no hammer action.
Hold the drill steady, and don't drag the drill bit in an out of the hole as it opens it up too much - keep a steady pressure.
Posted: Sat Dec 08, 2007 8:06 pm
by thedoctor
Use the smallest drill bit you can get hold of to start with 3mm is idea. This will go straight through and not get deflected so much. Then you can move up to a 5mm bit, then 7mm. Its a bit drawn out but it will guarentee you a good fix rather than take chances.
Posted: Thu Jan 22, 2009 10:53 am
by TheDoctor5
Posted: Tue Feb 03, 2009 8:57 pm
by norwich-plumber
please you do not need to drill 3 size drill bits :@) just use the right size for the drill bit and you will be fine as the other bloke said no hammer unless the render is hard
Posted: Thu Feb 05, 2009 8:36 pm
by the specialist
Hi depending on what you want to fix you could use a thunderbolt or rapier fix. These fixings will drive straight into light weight blocks quite easily with a cordless driver. If you haven't used them try one in solid masonry for which you drill a pilot hole. No rawl plugs required!
