replacing door
Posted: Wed Aug 20, 2008 4:41 pm
by stronach
My back door needs replacing as it is rotting away, it is a softwood door. I would like to replace it with a hardwood door. Can it be fitted into the original frame if that is softwood? The frame is in good condition.
replacing door
Posted: Wed Aug 27, 2008 8:04 pm
by jaydott
hi stronach
if you havent fitted the new door then yes you should b able to fit a hardwood door into the frame aslong as u buy the right size door ie 30 inch fram u would need to buy a 30inch door and shhot the door in but it should work any more questions wright back
