removing doorway from stud wall
Posted: Thu Sep 18, 2008 10:59 pm
by yorksvilla
I want to remove a door and frame from a stud partition wall what is the best way to fill the space left and how can I get the new section to mary with the wall so that it does not show up when decorated.
Posted: Wed Oct 29, 2008 12:07 pm
by toptips
once the frame has been removed you will be able to see the size and material used for the stud wall(timber or metal).Build a simple frame of a top,bottom and three uprights,fix plasterboard to the frame and skim over with finish plaster.
