Moving hanging kitchen cupboard
Posted: Thu Oct 16, 2008 7:56 pm
Moved from UK to sunny Gibraltar. Our kitchen has a line of cupboards and one is fitted with racks for draining the washing up. It is too far away from the sink and I want to exchange positions with the cupboard over the sink.
I've tried for ages to undo the fixing that hold the cupboard in place, but to no avail :twisted:
The fittings are visible through two 25mm holes at the top. I can see a cross head screw that adjusts position of the cupboard. Under the cross head screw a small hole where I can see the head of a small vertical screw/bolt. I'm able to move the screw head a little with screwdriver tip, but the blinking thing simply cannot be freed. Help
This might help - the hinges on the units are marked 'BLUM' Austria
