decorative cornice on fitted wardrobes
Posted: Sat Apr 11, 2009 11:50 pm
by doddgy
how do i cut the correct angles on my decorative cornice that is on top of my fitted wardrobes the cornice not only angles with the units but is angled forward and i do not know how to cut this angle to let 2 peices join together
Re: decorative cornice on fitted wardrobes
Posted: Mon Apr 13, 2009 8:58 am
by swadie
[quote="doddgy"]how do i cut the correct angles on my decorative cornice that is on top of my fitted wardrobes the cornice not only angles with the units but is angled forward and i do not know how to cut this angle to let 2 peices join together[/quote]
do you have a mitre saw ?
Posted: Tue Apr 14, 2009 4:14 pm
by doddgy
yes i have a mitre saw a compound saw got the lot i just need to know how to work out the 2 angles
cornicing
Posted: Wed Apr 15, 2009 7:02 pm
by sweetorb
hi doddgy
if the top of the wardrobe as you look down on it is "square",like a kitchen unit or table etc,then the angle is 90 degrees,therefore the "mitre" is 45 degrees. if i understand your question right,you mean that the profile of the cornice as you look at it end on leans forward,the cornice will be flat at the bottom (at least it should be or ull have trouble fixing it even if you manage to cut it,not impossible but tricky!!), as long as the flat section is placed flat and true to the base or stock (or whatever you want to call it!) of your mitre saw,with the profile leaning towards you, a cut of 45 degrees should produce the perfect mitre. it really is no diffrent from cutting a perfectly square peice of timber,the angle is always the same (assuming its 90 degrees) its just the profile thats diffrent.
why isnt there a symbol for degrees on my keyboard???
hope that makes sense doddgy...
