B&Q oak T&G boards for use as external cladding
Posted: Thu Sep 17, 2009 1:22 pm
I want to clad a small area ( 2 square metres) on the front of my house with wood. It is to cover existing painted wood cladding. The area does not get the sun, and does not get wet, except if maybe bad wind directs the rain under the porch roof. I have bought some B&Q Select T&G floorboards which are made from various layers of glued hardwood blocks (cross-plied) finished with about 7mm of solid oak.
I was wondering if anyone can tell me if using these as external cladding in the area described above might work, of if the moisture in the air, etc will cause the boards to fail?
Kev.
Kev.
