Trying to Make an MDF frame...please help!
Posted: Sun Feb 28, 2010 8:15 pm
by darrenwooly
Anyone help,
Im trying to make simple square frames from MDF, the MDF frame is 24 x 20 inches and the MDF is 1 inch thick, square.
Im doing a butt joint and not mitring the corners.
I pre-drill the holes, but when I put the screws in it splits right down the middle...
am I doing it wrong? are there any types of screws or drills I should use? I just bobbed to B&Q today and purchased a Makita drill and a 4mm drill bit.
any help would be appreciated!!
Posted: Sun Feb 28, 2010 9:56 pm
by Dan the man
MDF is murder to drill into through the side, I made something out of mdf last year and I had to glue and pin a strip of real timber to the edges and screw into it through the timber because it would just split, maybe you should try that, quarter inch timber.:)
Posted: Sun Feb 28, 2010 10:52 pm
by chris_on_tour2002
unfortunately a common problem when drilling into the edge of MDF.
try a larger pilot hole and tightly clamp a couple of scrap pieces of MDF top and bottom of the piece that you are screwing into - this may help prevent it splitting.
Re: Trying to Make an MDF frame...please help!
Posted: Sun Jun 13, 2010 9:30 pm
by dannypthechippy
darrenwooly wrote:Anyone help,
clamp tight the side of the screw holes b4 screwing
Help from DIY Doctor!
Posted: Mon Jun 28, 2010 10:05 pm
by TheDoctor4
Discover how easy it is to find vetted and insured tradesman local to your area with the help of DIY Doctor. Visit our Find a Tradesman area: https://www.diydoctor.org.uk/find_tradesmen/
