Replacement External Door
Posted: Fri Jul 08, 2011 11:36 am
by Peter Dixon
I need to replace a modern but rotten back door but the standard 838mm width is 7mm too small. The existing is 845mm x 1962mm - there is already the usual 2-3mm gaps all round (I assume the standard length of 1981mm can be cut down without problems).
Any suggestions? I do not really want to replace the frame if I can help it.
Posted: Sat Jul 09, 2011 5:09 pm
by Trades Master
This seems a lot to cut of the new door i would recomend you replace the frame, This is not hard to do, if you have the right tools you can have the job done in 2 hours.
door adjustment
Posted: Sun Jul 10, 2011 8:23 pm
by welsh brickie
buy a length of timber,and have it planed to the thickness you require.And then glue and nail it to the door.
Re: door adjustment
Posted: Sat Jul 16, 2011 1:02 pm
by greggy
[quote="welsh brickie"]buy a length of timber,and have it planed to the thickness you require.And then glue and nail it to the door.[/quote]
i had the same problem a few years back.
i did the same as welsh brickie said. but i got some matching mahogany
and put it on the hinge side.
