kitchen cupboard door adjustment
Posted: Sat Aug 11, 2012 5:43 pm
by goof
Having used up all the adjustment on the hinges my door still needs to move towards the hinge edge by about 3 mm. Can one obtain thinner carcase mounting plates?
- 316.92.627P1.JPEG (4.41 KiB) Viewed 2597 times
Thanks for your help.
Geoff.
Re: kitchen cupboard door adjustment
Posted: Sun Aug 12, 2012 1:22 am
by toptips
Hi Geoff,the screw that connects the hinge arm to what you call the mounting plate could be restricting further adjustment if it is too tight,try and loosen it a touch and see if this helps any and then tighten back up.
Posted: Mon Aug 13, 2012 7:57 am
by terryleth
Your kitchen cabinets will be tight initially when you use it it will become loosen. If still its causing you a problem try opening it closing it for sometime continuously it will become a bit loose but not much.
Posted: Fri Aug 17, 2012 7:20 am
by terryleth
Has your kitchen cupboard door problem solved?
Posted: Fri Aug 17, 2012 9:31 am
by goof
No solution yet, I still think a thinner mounting plate is the answer, or else I chisel out a 3mm deep recess in carcase end panel and sit the plate into it.
Thanks for all the answers so far.
Geoff.
