What To Use To Trim A Wooden Worktop To Fit Non Square Wall
Posted: Sun Oct 20, 2013 12:55 pm
by waterloo
What is the best tool to use to trim a wooden worktop to fit a non square wall? A hand saw,electric saw or a router.
Re: What To Use To Trim A Wooden Worktop To Fit Non Square Wall
Posted: Sun Oct 20, 2013 6:58 pm
by keeflester
If the unsquare wall is straight you should scribe a line, and use a router with a kitchen jig. If the wall is uneven then you should scribe the line and cut slowly and carefully with a jigsaw. Use a blade which cuts on the down stroke to prevent chipping the surface laminate. With care you should be able to match the wall within a millimetre. If you are tiling the splashback you will be able to conceal the gap.
