Advice Needed in Making Fireplace More Appealing
Sukh38
by Sukh38 » Thu Mar 10, 2016 9:47 pm
Hi all.
First time on here.
Please see attached a picture of the fire place. Its a wierd set up and just need some tips.
You can see there is about and 8 foot peice of wood running under the fire place which is the base to the fire place under that there r brick holdin up the base. (The laminate flooring has been fitted around the brick work)
What can i do to make this more appealing.
I cant rip it up as it will mean i will have to get new flooring put in.
I was thinking of boarding the front up. And painting it and maybe turning it into a sit down area maybe putting on some soft tops?
Any help would be great
tileclipproman
Re: Advice Needed in Making Fireplace More Appealing
by tileclipproman » Fri Mar 11, 2016 11:28 am
your picture never turned up.can you not make use of the alcove.
Sukh38
by Sukh38 » Fri Mar 11, 2016 10:41 pm
tileclipproman wrote:your picture never turned up.can you not make use of the alcove.
http://tinypic.com/view.php?pic=2dw7zut ... uNIF1mnzqB
Here u go
by welsh brickie » Fri Mar 18, 2016 8:19 pm
I think its best to remove the timber and the brickwork holding it up.
either lay the timber on the floor or raise it by adding some timber under it.
It is currently Sun Dec 22, 2024 5:38 pm
