Advice Needed in Making Fireplace More Appealing
Posted: Thu Mar 10, 2016 9:47 pm
Hi all.
First time on here.
Please see attached a picture of the fire place. Its a wierd set up and just need some tips.
You can see there is about and 8 foot peice of wood running under the fire place which is the base to the fire place under that there r brick holdin up the base. (The laminate flooring has been fitted around the brick work)
What can i do to make this more appealing.
I cant rip it up as it will mean i will have to get new flooring put in.
I was thinking of boarding the front up. And painting it and maybe turning it into a sit down area maybe putting on some soft tops?
Any help would be great
First time on here.
