Need help for desk build
Posted: Mon Jul 03, 2023 11:05 pm
Hi All
Totally new to DIY, I'm trying to build a desk with keyboard slide out. I bought 19mm thickness MDF (90cm W x 85cm D) (velvet ultra matt black if it matters) for the desk top, and the same thickness for the slide out part (70cm W and 50cm D) and bought the following legs for it:
https://www.ironmongerydirect.co.uk/pro ... ack-668033
mainly because of the height as I'd like it to be 80cm high.
For the keyboard slider thing I used the following:
https://www.amazon.co.uk/Emuca-bearing- ... 239&sr=8-7
With the help of a friend with a drill to drill initial (pilot?) holes we screwed the legs in (using these screws https://www.ironmongerydirect.co.uk/pro ... 200-644904) and added the slider however on completion the table is very wobbly, and with some lateral movement the screws become loose... not good!
Looking at it with my unsophisticated eyes it looks like the legs are too weak / thin / long for the desk top which is heavy, which I think is contributing to the wobble. Also I'm not 100% sure if I am using the right screws (was recommended from the iron store above). Thirdly I'm not sure my friend drilled the correct sized pilot holes for some of the screws (if you're reading this sorry Matthew) as some are a little loose / easy to fall in and don't really screw.
Firstly could someone recommend a set of legs that would support this desktop, as I feel like the legs I'm currently using are the problem, and also what screws would be needed for the job (and perhaps an explanation of how to drill correctly sized pilot holes to allow the screws to screw in to the MDF).
Where things get tricky is the keyboard slide out mechanism, you can see from the picture and the width of the keyboard slide out there is minimal space currently to accomodate a much larger 'top bit' for the table... I need the keyboard slideout to be 70cm width as I want to fit a MIDI keyboard that is 69.4cm width on the slide out... have thought about getting a less wide keyboard MDF piece and letting the keyboard hang over the edges, however as you can see from the pictures the Emuca runner / slider causes a ridge on both edges so the keyboard wouldn't fit on comfortably.
If anyone could assist this newcomer I would be greatly appreciated. As it stands I'm tearing out what's left of my hair with this and slightly regretting not buying a pre made desk.
