Interior "Borrowed Light"
Posted: Wed Oct 31, 2007 5:42 pm
by studoc
I'm about to have a hall/stairs/landing plastered so have an opportunity to install a "Borrowed Light" over a bedroom door. Can anyone direct me to some online specs that give advice or plans?
Posted: Wed Oct 31, 2007 10:05 pm
by kbrownie
Hi studoc,
put your post on the electrical part of forum some top notch advise to be had.
Regards
KB
Posted: Thu Nov 01, 2007 8:31 pm
by LCL
studoc
Cant really direct you to anywhere as I'm not sure what exists to cover this.
Few pointers though:
1. If the wall is load bearing, you'll need to put a lintel in a high level.
2. Line the structural opening with a softwood liner and fix the glass in place with glazing beads.
3. Finish it all off with architrave to match the door (might need to renew it around the door too!
Its quite a basic job, No 1. above is by far the most important.
Hope this helps
LCL
Posted: Fri Nov 02, 2007 5:06 pm
by studoc
LCL, thanks for the info. The wall is not load-bearing I can see the top of the bricks from the loft about 3 feet above. It seemed a simple enough project, I just hoped I wasn't missing something obvious .
