Stud wall strength??
kingnaji
by kingnaji » Thu Nov 15, 2007 7:59 pm
Hi all,
Am just beginning prep for my new kitchen, but the end wall is a long way from being square so to avoid a major optical illusion was going to put in a stud wall to remedy it.
Will this be strong enough to hold part of the corner kitchen units or anything else like that???
Obviously I will secure them to the studs and/ or noggins.
Is this a sensible idea??
canny
by canny » Tue Nov 20, 2007 9:04 pm
Use 4x2 timber @ 400mm centres. Put a 4 inch noggin at cabinet bracket height to carry cabinet's. Also fix noggins, 2 per 400mm gap. Fix head and sole plates to ceiling and floor joists, and end studs to walls.
Will be fine :)
It is currently Sat Jan 04, 2025 4:49 am
