Cutting an oak 40mm oak worktop
Posted: Tue Jan 01, 2008 8:25 pm
hi guys.. first post on here.
Need urgent advice. I Have got a 3mtr solid oak worktop which is 600mm in width and 40mm in depth. I need to cut out 2.1 mtrs which will be perfect to fit in my office.
This is to be supported by battens on both sides of the wall. The rear of it wont be supported by battens since its up against a suspended unit i've built in the wall. I've therefore put a batten across half way through from the left wall to the right.
I am massively concerned about cutting this and getting it right. I have a circular saw, a jigsaw and a hand saw. I cut it down a little on purchase to get it into the car with a circular saw. This caused chippings in the wood which are not attractive. I want a good finish. I think i may've pushed the circular saw through when cutting it. Which is my best option for cutting?
When i use a jigsaw its hard to get a straight line and when i examine it it becomes clear that things have been cut at an angle even though the jigsaw was held down.
Any and all advice appreciated please.
Also, any tips on supporting the worktop? Will it warp? should i stain both sides of it?
Look forward to hearing from you guys.
Jag
Jag
