Can anyone tell me what this fixing is called?
Posted: Mon Jan 07, 2008 9:46 pm
by jstannard
One of you clever chaps out there is bound to know the answer to this....we have an Ikea kitchen including several wall-hung cupboards with doors on the front that you lift up, ie hinged at the top. Each cupboard has two [color=red][somethings][/color] that, once you have raised the door, make it stay up/open. Closing it then involves a small amount of pressure downwards. They are about 7" long (not yet measured because am trying to find out what they are first). These could be air based in some way.
Anyway, they have stopped working so we have to hold up the door while we put things in/take them out. But I don't know the name for these [somethings] which makes sourcing replacements very tricky. And no (typical), Ikea doesn't offer spares....
If someone out there knows what I mean, I would be very grateful as would my husband and two children.
Posted: Tue Jan 08, 2008 1:57 am
by DONFRAMAC
Would you perhaps be referring to gas-struts, like those which support the tail-gate on hatch-back type cars? I recall my father renewing one on his car,many years ago, and it was a real doddle.
Posted: Tue Jan 08, 2008 11:27 pm
by marrtin
Fitted several Ikea kitchens and know exactly what you mean, but not what they are called.
cupboard door stays I think, or door support brackets.
Re: Can anyone tell me what this fixing is called?
Posted: Wed Jan 09, 2008 1:56 pm
by multiworx
yes they are domestic gas struts and some can be re-gased try sgs engineering they will be able to point you in the right direction.
hope this helps
Posted: Thu Jan 10, 2008 2:19 pm
by Bantaman010
jstannard wrote:One of you clever chaps out there is bound to know the answer to this....we have an Ikea kitchen including several wall-hung cupboards with doors on the front that you lift up, ie hinged at the top. Each cupboard has two [somethings] that, once you have raised the door, make it stay up/open. Closing it then involves a small amount of pressure downwards. They are about 7" long (not yet measured because am trying to find out what they are first). These could be air based in some way.
Posted: Thu Jan 10, 2008 2:23 pm
by Bantaman010
They are called stays, you lift to lock and lift again to release. The can be bought from the major DIY stores just check you get the proper sized screws to do the job.
