Boxing in old Potterton boiler - regulations?
Posted: Mon Apr 07, 2008 5:16 pm
Hi.
I am replacing my old kitchen doors to give my kitchen a home makeover, and have decided to build a housing cupboard round my boiler as it is hideous and really makes the kitchen look bad even with the new cupboards.
My Dad is going to do it for me, he is a joiner, but we need to know the regulations for boxing it in.
It is a Potterton Netaheat Electronic. I can't find any serial numbers etc, that's all it says on the front, but I suspect it is pretty old (maybe more than 10 years).
It is situated in the corner of my kitchen. The back of the boiler is against an outside wall, and it is about 3 inches from the ceiling and about 2 feet above the worktop.
I don't mind leaving the top and bottom of the cupboard off (ie just building around it and putting a door on the front) because you don't see these areas, and I have purchased two aluminium vents to put on the side of the cupboard. The other side of the boiler is about 2-3 inches away from the wall so I will probably not even be putting that side on the 'cupboard' (ie it will basically be a front with a door and a side with vents, no top or bottom).
So, has anybody got any recommendations or suggestions - does this sound okay, and do you think it will provide adequate ventilation? I will make sure the cupboard comes apart easily for servicing etc.
Louise
What else do I need to do?
Louise
