by htg engineer »
Fri Apr 18, 2008 8:14 pm
Vented all air from pump vent ? turned pump speed to maximum ?
Are you sure the zon valve or three port valve ? fitted correctly and working ?
room stat calling for heat ?
Select hot water, remove actuator and trun the valve manually - if the radiators heat it's the actuator at fault.
