Can anyone help??
My radiators used to only get warm on top. A plumber eventually diagnosed the problem as
being the external bypass in my heating system being fully open causing alot of the hot water to go directly back to the boiler. He closed the bypass fully and now the heating is 10x better
My questions are... should he have fully closed this bypass off? Is there no in between Fully open or fully closed? If the boiler has an inbuilt bypass what should the external one be set at? Will it damage my system etc if its fully closed?...
Any help would be VV much appretiated !!
