by magseywagsey »
Sat May 10, 2008 5:28 pm
Hi Rosebery
Thanks for your reply and advice.
To clarify it is the expansion tank overflow.
I have been doing some testing and even though it is coming from the expansion tank overflow, I think you maybe right with regards to the cylinder coil.
I have turned everything off the timer that calls for heat and water, the cold water tap to the cold water tank in the loft. I turned on the cold water tap for the bath and nothng happened, I turned on the hot water taps in the bathroom and the kitchen and even though I have isolated the water to the cylinder (there is still water in the tank) it did something to the expansion tank and it started dripping again. I then removed some water again from the expansion tank and tried this again, obviously there is less water in the cylinder, so it has drained more off and the cold water feed is still off and there was no more dripping, all this time my boiler is still on, just incase that has any bearing on this problem./
So I think you maybe right, (please reply and let me know) it probably is the coil and it does have a leak. If this is the case does that mean a new cylinder tank., and will this be anexpensive job to replace it.
I can remember when my ex-partner was putting this cylinder tank in, it was a pig of a job to do.
Answers to your other queries:-
The pump speed is set on 2
The F & E configuration as far as I know is still the same as it ever was when the central heating system was put in, unless the man who replaced the 3 way port did something. Anyway, I don't know what this is and where to look for it.
The vent pipe in right up under the eaves
Haven't touched the boiler stat. Only the knob you set to high in winter, the instructions say you have to do this, at the moment it is on 4 I turned it down just in case this helped, but it didn't.
So perhaps like you say when the man came to do the 3 way port, and put some sludge stuff in the system, well I think that's what he put in, and like you say it is corrosive, it probably has made a hole in the coil if it was wearing thin. Didn't realise that happed to the coil, in fact I did't realise it had a coil in it. sorry bit dumb there.
Look forward to your nexrt post.
I hope this helps you further, which in turn will help me, so I know what to do next, and price things up, because if it is the cylinder tank, Iwon't be able to do that, and I won't ask my ex because I know what the answer will be, even though his daughter will benefit, but, hey not your problem.
Thanks again
Maggie.
