boiler not firing. potterton puma
Posted: Thu May 08, 2008 8:24 pm
by stevejames199
potterton puma 100e boiler not firing. flow switch appears to be working cos can see it moving and its pushing switch on. has been making hissing noise when you put hot tap on for few secs then ok (since it was "serviced " nearly 2 yrs ago.) ive been told diverter valve buggered. or the fault finder indicates it may be air pressure valve, any ideas???? steve.
Posted: Fri May 09, 2008 9:35 pm
The boiler is not firing on central heating or hot water ? if it was just the diverter at fault the boiler would fire up but only for a short while.
does the pump and fan run ?
if the fan runs, does this operate the air pressure switch ?
Need more info to be able to help.
puma boiler
Posted: Fri May 09, 2008 10:07 pm
by stevejames199
thanks for reply. boiler not firing on water or heat. pump runs when swithed on but fan not running, im assuming you mean extractor fan at top of boiler
puma boiler
Posted: Fri May 09, 2008 10:14 pm
by stevejames199
not sure what to listen for (air pressure switch) is this located near top of boiler, quite flat with 2 pipes to it?
potterton puma 100e not firing!
Posted: Fri May 09, 2008 10:25 pm
by stevejames199
boiler not firing on heat or water. pump runs when heat switched on, fan not running, im assuming you mean the extractor fan located at top of boiler, air pressure switch near top on side cant hear anything.
Posted: Fri May 09, 2008 11:26 pm
by stevejames199
water pressure fine, tested wires to fan and no power to it when heat switched on and pump runs
Posted: Sat May 10, 2008 10:07 am
No power to fan ?
possibly PCB at fault
