Hot Water is way too hot.
Posted: Mon Jun 23, 2008 3:00 pm
Since I came back from holiday my hot water is getting too hot. The hot water cylinder has a thermostat attached to it & is set for about 55c. The hot water is set to come on a couple of times a day morning & night for about an hour each time, just enough usually to bring it up to temp.
When I went on holiday I set the timer to off for both Heating & HW.
Since returning from holiday, the water has been getting far to hot (if I adjust the thermostat on the HW cylinder it 'clicks' at around 70c). When both the HW & CH are 'off' I can hear a noise that sounds like a pump of some sort is running. I suspect that this is the hot water.
If I 'advance' the HW to 'On' this sound does not change & I do not hear any other clicking or whirring of valves etc.
If I 'advance' the CH to 'On' or flick the heating isolation switch this noise goes off. (Although it's obviously quieter when I flick the heating isolation switch! :) )
Can anyone give me any pointers as to what the issue might be? Someone has suggested that it's the 'timeclock'? Is the timeclock just the timer panel on the wall where you set the on & off times for HW & CH? If so is it easy to replace if you're fairly competent with electrics? :)
