by htg engineer »
Thu Jul 17, 2008 5:36 pm
No - fitting radiators and pipework yourself is acceptable.
Your question about the lifetime of radiators and pipework is not as simple as you may think.
It all depends on:
how it was installed - sleeved and protected where necessary
flushed and inhibitors added
inhibitors added eveytime the system was drained.
If it was correctly installed, sleeved, coated/protected flushed with inhibitors added the system will be in very good condition and should cope with a new boiler for many more years.
Any of the above not done properly then there's a risk it may not cope with a new pressuried boiler and may leak.
Weigh up the costs - leave it and it may be ok. Or renew it all properly as described above, sleeved, coated, flushed and inhibitors added and you will not need to re-pipe or change radiators again in your lifetime.
htg
