by nitro23456 »
Sat Sep 13, 2008 12:35 pm
Does the hot water heat up when the central heating is on? (you'll have it on soon anyway no doubt)
I once lived in house where in the summer I would have to have the programmer set to both (ie heating and hot water) to come on but have the room thermostat down (like at 17 degrees) so the rads don't heat as the ambient house temp was above 17 degrees and thus the CH wasnt calling for heat whereas the hot water stat on the cylinder set at 60 degrees was..... bingo hot water.
Its a work around.
If your only reason to get £1900 worth of boiler is the problem you are having, I wouldnt bother, and focus more on sorting this problem out.
Im only a DIYer and I'm sure the likes of HTG Engineer et al will be able to advise better, but it sounds more and more like an airlock...... try touching the feed and return pipes that come out of your hot water cylinder.... when they should be hot with the boiler running. They should both be hot to the touch.... if the bottom one isnt, your coil is airlocked inside the cylinder.
If you dont know what pipes are what, look at this picture:
http://www.screwfix.com/sfd/i/cat/65/p1053465_x.jpg
or
https://www.diydoctor.org.uk/projects/do ... r%20system:
The holes on the side are the feed (top) and return (bottom) with the hot water draw off at the top and immersion space just below. You should have pipes to touch in these locations. Remember the rotation orientation of the cylinder might be different in your house but the principle is the same.
If, indeed the coil is airlocked, you just need to crack open a nut and reclose it when the air has escaped and water starts to come out. 5 minute job that might save you £1900!!
If it isnt this, its beyond the scope of my knowledge I'm afraid!
Another thing to check is that you dont have any overflows dripping from the loft tanks to the outside as it may be an entirely different problem altogether.
