No Hot Water - Central Heating OK - Help!
Posted: Tue Sep 09, 2008 6:43 pm
by mdvUK
I have a Potterton II Kingfisher RS50 conventional boiler. It's an open vented system (i.e with a hot water storage tank in airing cupboard and two tanks in loft)
Central heating works fine, but the boiler does not fire up when the program timer switch is selected to run HW only (pilot light is on).
Is this a program timer switch fault, pump or a diverter valve?
Any help in diagnosing the problem much appreciated! :)
Posted: Thu Sep 11, 2008 2:59 pm
by nitro23456
what do you have your cylinder thermostat set to?
Posted: Thu Sep 11, 2008 8:46 pm
by mdvUK
HI Nitro
My cylinder (storage water tank) thermostat is an odd one - the dial has numbers 1-9. Currently this is set 5. I'm having to switch this on to heat the water as the boiler is not storing hot water in this tank/supplying it to the taps.
The boiler thermostat is set at 2 (1 being for summer and 4 for Winter months)
Any clues?
Posted: Fri Sep 12, 2008 10:25 am
by nitro23456
I am presuming you are referring to switching on the electric immersion element to heat the water.
From the information you have given it sounds like the mid-position valve (3 port valve/diverter etc) is jammed to central heating. Have a look at it and see.... try manually moving it to the mid position as a temporary fix so it heats both.
Either this or for some reason your cylinder coil is airlocked which is unlikely unless you have had some work done?
Im sure one of the experts on here will confirm.
Posted: Fri Sep 12, 2008 5:55 pm
by mdvUK
Hi Nitro
The diverter is a drayton MA4, it's currently in the mid position and does not change even when the heating is selected.
I had some work done a few months ago, (new rads installed) and everything was working fine. This happened suddenly last week....
I've been quoted £1900 for a new Vaillant ECOTEC 831, fully installed with all parts and removal of immersion tank etc etc.
The boiler is costing 950, pipe and fittings 200. Power flush 200, rest is labour. Is this about right - can i purchase the boiler myself and make a significant saving?
Posted: Fri Sep 12, 2008 8:22 pm
With your system can you have central heating on by itself ? or do you have to have hot water on too.
Does it have a 3 port valve, or is it as I think - a gravity hot water system, can you confirm ?
If it is gravity hot water, it may be an airlock in the primaries.
htg
Posted: Sat Sep 13, 2008 11:40 am
by mdvUK
I can confirm that when the heating is switched on, the hot water must also be selected. I think it is a 3 port valve. It is an open vented system, and I beleive it is a gravity fed system
How do I remove the airlock?
Many thanks for your help!
Posted: Sat Sep 13, 2008 12:35 pm
by nitro23456
Does the hot water heat up when the central heating is on? (you'll have it on soon anyway no doubt)
I once lived in house where in the summer I would have to have the programmer set to both (ie heating and hot water) to come on but have the room thermostat down (like at 17 degrees) so the rads don't heat as the ambient house temp was above 17 degrees and thus the CH wasnt calling for heat whereas the hot water stat on the cylinder set at 60 degrees was..... bingo hot water.
Its a work around.
If your only reason to get £1900 worth of boiler is the problem you are having, I wouldnt bother, and focus more on sorting this problem out.
Im only a DIYer and I'm sure the likes of HTG Engineer et al will be able to advise better, but it sounds more and more like an airlock...... try touching the feed and return pipes that come out of your hot water cylinder.... when they should be hot with the boiler running. They should both be hot to the touch.... if the bottom one isnt, your coil is airlocked inside the cylinder.
If you dont know what pipes are what, look at this picture:
http://www.screwfix.com/sfd/i/cat/65/p1053465_x.jpg
or
https://www.diydoctor.org.uk/projects/do ... r%20system:
The holes on the side are the feed (top) and return (bottom) with the hot water draw off at the top and immersion space just below. You should have pipes to touch in these locations. Remember the rotation orientation of the cylinder might be different in your house but the principle is the same.
If, indeed the coil is airlocked, you just need to crack open a nut and reclose it when the air has escaped and water starts to come out. 5 minute job that might save you £1900!!
If it isnt this, its beyond the scope of my knowledge I'm afraid!
Another thing to check is that you dont have any overflows dripping from the loft tanks to the outside as it may be an entirely different problem altogether.
Posted: Sun Sep 14, 2008 10:53 am
If on the programmer you cannot have central heating on, by itself then it's a gravity hot water system you shouldn't have a three port valve on your system.
It's either an airlock or a blockage in the primary circuit, Get an engineer out to check they will probably pull the stat and boil the airlock from the system, it's the quickest and most effective way.
htg
