Air in my central heating
Posted: Sun Sep 28, 2008 10:30 am
by bechensfeld
A volume of air bubbles around the gas-fired (Potterton Profile 50e with
individual stats on each radiator) and it won't bleed out of the rads or the escape value at the tank. 2 plumbers have suggested I fire boiler on max temp. turn on one rad only and bleed it but has made no difference. Header tank is fine (water is rusty coloured but we are in a sandstone area which may cause that) so is there anything I can do before draining and flushing the whole system? Plumbers say this can take many hours which they have to charge for just to watch and wait. Fair enough but I would like to leave this to the last resort if possible.
Posted: Fri Oct 03, 2008 12:37 am
by screech
best way to clear air is to stop/start the pump a few times and not letting the boiler fire
Posted: Fri Oct 03, 2008 5:33 am
by Steve the gas
If you feel able drain it down and refill a couple of times -- see if it improves, but research how to do it first of course.
Hth
Posted: Fri Oct 03, 2008 9:35 am
How do you there's air in the system, is it not the pipes/radiator valves making a noise ?
Normally venting the pump and radiators would clear the air.
Are all the radiators heating - if they are then there's unlikely to be much air in the system.
htg
